R/A steam trap question
& things are pretty <i>cut & dry</i> going(2 pipe),, however there are 2 rads on the top floor(3floors) of 45 sq.ft each that have the R/A traps installed <i>sideways to drain</i>.<BR>Everything looks original, and these are not special config traps,,, does this sound OK?<BR>The <i>rough-in</i> comes through the plastered wall, so I`ll have to really block-up the rad if it`s a prob.<BR>Any ideas?<BR><BR>Dave
bump0 -
Dave,
what's R/A?Retired and loving it.0 -
I'm thinking .....
right angle.
Should still work that way. I have seen a few installed this way with no apparent issues.
JimThere was an error rendering this rich post.
Sorry for my description,
and yes, Jim is correct.
It`s a standard right-angle low-pressure steam trap, but installed on the rad discharging sideways into the through the wall piping.
I`ve already spoken to Frank(Steamhead)Wilsey, and he says it should be OK,, its just not the usual way I see them. ;-)
Dave0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
