burying wet return
charlie_22
charlie_22 Member Posts: 18
I plan on burying two sections of my wet return and insatlling ball valves with flushing ports should I use copper? If so how do I protect it from the concrete? And what are some other options for this application thanks Charlie Norgalis
  • Big Ed_4
    Big Ed_4 Member Posts: 3,362
    Wet Returns
    Use iron pipe for the wet return. I would the last pipe lasted 70 years.. What you need to worry about is the acidity of the soil. You can fill around the pipe in the trench with lime stone to neutralize the soil. Rap the pipe at slab level with pipe insulation or even a rag just incase of pipe expantion and friction wear ..
  • Typically I use copper
    below the water-line,, especially anything buried.
    It just sets my mind at ease knowing if there`s ever a problem.
    Just wrap some foam-pipe insulation at the ends where you protrude through the concrete as it will react negatively with any alloy touching it.
    The valves/drains for flushing are a GREAT IDEA!
    This sounds like a familiar post/name! ;-)
    Dave
  • charlie_22
    Dave
    We spoke two weeks ago about raising and dripping my main I have one more runout and the main vents to do and I will be starting on the return piping.I would like to post some pics of my work but I am much more interested in steam system work than computers and digital cameras but I will see if I can get someone to help me post pics.Thank You for your time and advice Charlie
  • charlie_22
    Big Ed limestone
    Ed: Where do you get the limestone plumbing supply or mason supply?
  • Don't bother with limestone
    Just insulate the whole pipe before you bury it . It'll save you some dinero in the long run too . You won't be heating the slab up with return water . I'd cover the pipe with sand and cap it with a few inches of cement mix .
  • charlie_22
    makes sense
    that makes sense that foam insulation never decomposes thanks for the advice
  • Big Ed_4
    But
    .. And there is alway a but. In old homes they use to have dirt floors and burnt coal. All that coal ash brought up the acidity of the dirt. Covering the pipe with insulation is good to prevent heat loss. But if below the slab is wet the water will seep in and corrode the pipe. Then use lime stone or marble chip to netrualize arond the pipe. All depends on the job. How long did the old one last. Does the trench look dry. Food for thought on your job..
  • I agree Ed,
    many basements (including mine) used cinders for fill.
    When the railways were "King", they had to get rid of the stuff somewhere, it was a popular under concrete fill.
    I would think copper is the best defense to anything underground,, except where it protrudes.
    Dave
  • Big Ed_4
    Copper can be used
    Just install dielectric unions where the copper connects to the iron.
  • Well,,,,,
    as you know Ed,, electrolysis is a whole other topic. :-).
    Dave
  • Big Ed_4
    All due respect to all ..
    Hope you were not defended , I just wanted to help , so I just added the unions . Goes for everyone.. That's how I learn too .. Heck after 35 year I have enough experience to know , that I don't know it all ..
    40 years if you figure as a kid helping my Dad and Grand Dad , I was offered a full time job at 18 in this industry. I took if figuring I will will do it temporary .Thank God inmagine if I wanted to make a career out of this !!! LoL
  • Ed, Ed, Ed,,,,
    I most certainly respect your experience,, you seem like a very good tradesman, and what I said was meant in the highest esteem!
    Let`s try not to be so touchy with each-other in the future OK? :-)
    Dave
  • Big Ed_4
    Very Good
    I am fine , heck after dealing with the public all these years I am like rubber ... LoL
  • charlie_22
    Big Ed Limestone
    Ed: The house was built in 1936 I bought it from the original owner she said it always had oil heat and it has a concrete floor I would say the soil is damp so I will definatly use the crushed limestone. Were is the best place to get it? thanks for all your advice
  • Ash and cinders can be a problem. About ten years ago we installed a copper pipe in a trench from a well to a house and unknown to us the trench crossed an old pit used to dispose of ash/clinkers. The pipe rotted out in less than 3 years! Here's a good link on the subject:
    http://www.copper.org/applications/plumbing/techcorner/prevent_corrosion_cu_tube_buried.html
    We wrapped the replacement pipe in vinyl electrician's tape and used a neutral backfill. We haven't had a problem with the pipe since then. Limestone sand is available in some places as is crushed marble. I've seen marble chips at Home Depot.
    On the link - Take a look at how they came through the concrete. I'm going to try that next time I have a similar installation.
    - Rod
  • charlie_22
    info
    Thanks alot for the advice and the link
  • bob young
    bob young Member Posts: 2,177
    buried vs. getting buried
    USE " K " Copper & a pipe sleeve. ash & cinders are murderous on pipe. when you bury pipe its always a gamble. & you can take that to the bank.protect from moisture outside------inside is O.K. lol
  • MikeyB
    MikeyB Member Posts: 696
    Returns
    When I was working in the trade, we always replaced the old underground returns w/type L copper, and insulated it, Sometimes you could abandon the underground return & run a new return on top of the floor/slab if conditions permitted. If you want extra insurance use type K tubing, a bit more of an expense but heavier tubing.. And always sleeve you tubing/pipe as it passes through a slab or foundation,,, that was always common & good practice. And the extra valves are always a good choice for cleaning
