R/A steam trap question
& things are pretty <i>cut & dry</i> going(2 pipe),, however there are 2 rads on the top floor(3floors) of 45 sq.ft each that have the R/A traps installed <i>sideways to drain</i>.<BR>Everything looks original, and these are not special config traps,,, does this sound OK?<BR>The <i>rough-in</i> comes through the plastered wall, so I`ll have to really block-up the rad if it`s a prob.<BR>Any ideas?<BR><BR>Dave
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,649
    Dave,
    what's R/A?
    Retired and loving it.
  • Jim Bennett
    Jim Bennett Member Posts: 607
    I'm thinking .....
    right angle.
    Should still work that way. I have seen a few installed this way with no apparent issues.
    Jim
  • Sorry for my description,
    and yes, Jim is correct.
    It`s a standard right-angle low-pressure steam trap, but installed on the rad discharging sideways into the through the wall piping.
    I`ve already spoken to Frank(Steamhead)Wilsey, and he says it should be OK,, its just not the usual way I see them. ;-)
    Dave
