New Watts RBFF install
in spite of our recommendation we could not talk the homeowner into zone valves w/ a wilo pump. The picture features a new 3-way-valve by watts. This job was done by A Superior in S.I.N.Y. & Comfort P&H in Jersey.
Nice Job!
Let me guess "One pump can't do the job" or "What if the pump goes bad,I'll have no heat" or "My neighbor,co-worker,landscaper etc said zone valves are no good"0 -
What if the pump goes bad,I'll have no heat was the reason. I don't know how to combatt that one.0 -
As you also may notice I used a spirotop on the separator. It works much better than the one that comes with it.0 -
I
just noticed that,very nice!What brand LLH is that?0 -
Whats an LLH ?0 -
Joe K was doing this job with me & he turned me on to this Watts RBFF valve on the expansion tank0 -
LLH
Low Loss Header, looks like a Callefi, Very nice install, what do the zones consist of?0 -
fin tube0 -
Gotta try
one of those Watts valves! Nice Lookin' Work!0 -
Bad Pump
So, please excuse my ignorance, but; what happens in that
design if the Primary circ goes bad? Will system circs induce flow through the LLH to the zones? If not, what's the diff?0 -
What happens
when the primary pump in a P/S goes bad? Nothing,same as a LLH0 -
Few questions
Why is there what looks like a dielectric union, on the boiler supply? Personal preference?
Should the relief valve be vertical?
What did you not like about the Caleffi vent?
-or-
What does the Spiro vent do that the Caleffi did not?
- 167 Indoor-Air Quality
