Heat Cryte .. ever try it ?
ScottMP
ScottMP Member Posts: 5,882
a staple at the end of each loop and they go in very easy.
The tubing jackets are for the expansion joints of the slab. They are split and go on very easly.
Scott
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=237&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • ScottMP
    Heres a few photos of a new
    garage we are doing. This is Heat-Crete (I forget the spelling). Two Inches of foam board with the tubing nubs built right in. Sure makes the install nice and quick.
    Scott
  • Don Regan
    Don Regan Member Posts: 43
    Crete-Heat
    Nice photos Scott.
  • Bob Bona_4
    can
    you walk the tube into the gaps, Scott, or is it hands and knees and mallet.
    GC do the board laydown or you, and what do you cut it with?
    I'm liking it.
  • John Starcher_4
    John Starcher_4 Member Posts: 794
    I haven't, but...
    ...I have a sample of it sitting on the counter in my office. Neat stuff, and I can't wait to try it!
    BTW, Scott, how'd ya like the game last Sunday?? ;-)
  • Scot_2
    Scot_2 Member Posts: 3
    Fasteners?
    Nice photos, and great tip. It appears that there is a fastener at each loop and then some tubing jacketing on the long runs? Are these easy to assemble? Do you have to slide the jacketing on or is it split to slip over? This looks fairly simple with less bending over than normal..
  • Here's the Crete-Heat website for anyone interested.
    http://www.crete-heat.com/
  • Don Regan
    We have found...
    that if you nest the tube to the knobs on the outside radius, no staples are required. The tendency is to want to pull the tube away from the knobs and this will result in the tube wanting to pop up on the corners. Pictures on how this should look for each width of tube spacing is on our web site.
    Thanks all for your continued support.
    hot_rod Member Posts: 25,354
    PAP works nicely
    in Crete-Heat. As does the 3/8 Watts Onix. With Onix there is no problem keeping the loops down, same with PAP or FostaPex.
    hr
  • Scot_2
    Thanks
    Thanks for the info, once again great tip!!
  • Barry Fawcett
    Barry Fawcett Member Posts: 4
    also consider Creatherm panels
    www.creatherm.com
    Same concept but more choices in thickness and R value.
