Warm rooms, cold rooms.....
Joni
Member Posts: 1
We got some wireless thermometers for Christmas, and are validating our earlier belief that some rooms in our house are WAY warmer than others....we have lived in this house for 18mos and have had this problem continuously even though we have turned the 3 wing nuts on the ductwork to "summer" and "winter" with the seasons. Apparently there is more that can be done, because the heat is still very different from room to room even on the same level. Am I supposed to be doing something other than turning the wing nuts?
you can try
running the blower continuously when home or have the system balanced by a pro balancer, that's what those dampers are for--balancing
when the blower shuts off no air is moving or blending
how far off are the rooms from each other??0
- 119 Chimneys & Flues
- 76 Pipe Deterioration
