Reverse Chiller
I'm not up on the specifics.
Reverse Chiller
In an earlier thread there was some discussion about a reverse chiller system from York I think. I was wondering if this RC is really an air to water heat pump? If it is, is it a split system with an indoor and outdoor unit. I am really interested in discussing this topic.
Mike0 -
It is an air to water system. We have had good success with them.
The new units are not split, they are packaged units. I think the draw is to hydronic guys who don't have the ability to weigh in a charge or braze.
There are still a few split units left however but the inventory is getting limited. I am crossing my fingers that they still have a 5 ton left.
Here is a link:
Aqua Products Reverse Cycle Chiller0 -
RC questions
Hi Josh,
At what outdoor ambient are these machines working to?
Are these York units modified by aqua products?
Do you require a buffer tank for small radiant load calls?
Thanks,
Mike0 -
Their literature says down to 17 Degrees.
Actually the units were being made long before York had anything to do with them. York bought Aquaproducts last year.
Yes, a buffer tank is needed. We have been doing about 25 gallons per ton with good success. If you have micro-loads you may want to do more.0 -
17 degrees
Then what takes over? Seem like a sellable product, do you buy from YORK distributor? Bryan0 -
I'm getting em from a couple of different sources. They don't have to be York distributors.0
