Reverse Chiller
I'm not up on the specifics.
  • Mike Dunn
    Mike Dunn Member Posts: 189
    Reverse Chiller
    In an earlier thread there was some discussion about a reverse chiller system from York I think. I was wondering if this RC is really an air to water heat pump? If it is, is it a split system with an indoor and outdoor unit. I am really interested in discussing this topic.
    Mike
  • Josh M.
    Josh M. Member Posts: 359
    It is an air to water system. We have had good success with them.
    The new units are not split, they are packaged units. I think the draw is to hydronic guys who don't have the ability to weigh in a charge or braze.
    There are still a few split units left however but the inventory is getting limited. I am crossing my fingers that they still have a 5 ton left.
    Here is a link:
    Aqua Products Reverse Cycle Chiller
  • Mike Dunn
    RC questions
    Hi Josh,
    At what outdoor ambient are these machines working to?
    Are these York units modified by aqua products?
    Do you require a buffer tank for small radiant load calls?
    Thanks,
    Mike
  • Josh M.
    Their literature says down to 17 Degrees.
    Actually the units were being made long before York had anything to do with them. York bought Aquaproducts last year.
    Yes, a buffer tank is needed. We have been doing about 25 gallons per ton with good success. If you have micro-loads you may want to do more.
  • Bryan_16
    Bryan_16 Member Posts: 262
    17 degrees
    Then what takes over? Seem like a sellable product, do you buy from YORK distributor? Bryan
  • Josh M.
    I'm getting em from a couple of different sources. They don't have to be York distributors.
