Wall mounted Radiators
William Faust
Member Posts: 168
How close are you to Philadelphia, PA?
I have a wall mounted radiator in my garage. The garage in on a concrete slad and it is above the basement where the boiler is. The current radiator has a hole in the bottom and only half of it ever heats. It is unrepairable, so i am told, and I can not find another one to replace it without spending a fortune.
Any suggestions on where I can find a wall mounted radiator to replace it? Or any other suggestions on how I can heat the garage. I have tried placing a floor radiator on the wall, but the maid-O-Mist valvue is constantly blowing steam out, and the radiator is leaking on the bottom in the middle of the radiator. Thanks...0 -
where are u located?
I have some cameo radiators, taking up spaces.. What are the sizes?0 -
at the home of the next week superbowl champs
Chicagoland....0
- 167 Indoor-Air Quality
