Wall mounted Radiators
How close are you to Philadelphia, PA?
  • CJL
    CJL Member Posts: 7
    I have a wall mounted radiator in my garage. The garage in on a concrete slad and it is above the basement where the boiler is. The current radiator has a hole in the bottom and only half of it ever heats. It is unrepairable, so i am told, and I can not find another one to replace it without spending a fortune.
    Any suggestions on where I can find a wall mounted radiator to replace it? Or any other suggestions on how I can heat the garage. I have tried placing a floor radiator on the wall, but the maid-O-Mist valvue is constantly blowing steam out, and the radiator is leaking on the bottom in the middle of the radiator. Thanks...
  • where are u located?
    I have some cameo radiators, taking up spaces.. What are the sizes?
  • at the home of the next week superbowl champs
    Chicagoland....
