air scoop issues
in two weeks I went to replace an expantion tank and went to give it a tighten up w/ my 10" channel locks and the American air puger cracked....anyone have issues w/ these too...does the cast get brittle as it ages....should I just hand tighten it? kpc
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=323&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • burninben
    burninben Member Posts: 33
    I have good luck w/ spirovents. I have had issues tightening nipples too tight into a female cast fitting.
  • Weezbo
    Weezbo Member Posts: 6,231
    something that i learned along time ago...
    when i could remember they were called air scoops:)), sorry, is that the nipple that you remove "seats" over time and rust forms at that depth...remove it and you wont have that problem any more.
  • kevin coppinger_4
    kevin coppinger_4 Member Posts: 2,124
    in both cases...
    it was just the extrol tank..nothing else...boiler fill was elsewhere...no rust.I was not even to the depth of where it was when I removed the old tank. kpc
  • Never had
    that happen to me yet Kevin, but having said that, the next one probably will. But I do run a tap through first, just a habit I got into.
    Dave
  • use a wire brush
    > cast fitting.
    on both male and female threads, then teflon, then pipe dope. you wont have to tighten much more than hand tight. Bob Gagnon
  • use a wire brush
  • Al Corelli_2
    Al Corelli_2 Member Posts: 395
    I've seen that happen...
    Since, I've learned to only tighten things "half a turn before they break".
    Some cast fittings appear to get brittle after use.
  • Lurkin' Murkin'
    Lurkin' Murkin' Member Posts: 136
    A bucket for monsuior?
    Also had that happen, when installing a new tank directly into an old system's scoop. Used joint compound over teflon tape and only hand tightened, like usual. Scoop split clean in half. Late night job for a friend, on a real cold night - kept it running with wood clamps and duct tape until able to get parts next day...
  • Bob Bona_4
    feel your pain
    probably had it happen about 4-5 times in the last 17 years. A few were on night calls. Can you say hissyfit, anyone?
    These days, it's the usual teflon, then Megaloc, and then an 8" adjustable w/ one hand delicately tightening until snug. I still cringe.
    Had more than one Spiro incident where if the nipple gets too tight in the Spiro it actually clamps off water passage into the Spiro. The nipple end somehow pushes the rubber grommet inside to block water. Talk about aggravation when the boiler won't get fed at 6 pm!!
  • Bryan_17
    Bryan_17 Member Posts: 4
    Spirovent
    I found that if you over tighten the nipple on the 1/2" inlet you can jam up the internal spiro. By doing this the vent will not work properly.
