Whats your boiler water temp this morning?
-3°F this AM - My Knight was perking at 143°F - Return was 124°F - running three zones of baseboard.
I expected higher temps on baseboard and do see them occasionally.
I never thought I'd stop to check out the boiler every time I go by but I do. Heck, it's better than TV.
«1
  • Steven Gronski
    Steven Gronski Member Posts: 98
    Gotta love technology
    Got up this morning,3 degrees out at 6:00 Am here in Cranston RI, My first winter with a Vitoden, so I went down to the basement to check the Vitodens water temp, the little green light was on and a whopping 154 degrees of water, keeping my house at 68 degrees,with 3 zones of baseboard on constant circulation, where the old blue would have been cranking away at 180 or so. I am interested to see what the Vitodens on the radiant jobs I installed this year, are doing for watertemps on an almost design temperature day.
  • Constantin
    Constantin Member Posts: 3,796
    6.4 Degrees Outdoors...
    Ms. Vitola is at 134°F (just finished reheating the indirect), the supply to the RFH system is 96°F. ~4.6 Gallons of #2 fired in the first 8 hours of "today" (the WEL does not observe DST changeovers).
  • Tony_23
    Tony_23 Member Posts: 1,033
    Mine
    It is -14 here in SWNY. A "little" below design :) The "book" says 0, I've always used -5 to -10 dependant upon specific locale. Having lived here all my life I know the areas that are "needy".
    Anyway, my system isn't complete (shoemaker's kid) but my Ultra is at 140. This old farmhouse from 1875 isn't quite as tight as I was told :( I've got to remove some vinyl siding this Summer and see where the breeze is coming from. Every time the wind changes direction up on this hill, I get out the incense stick and caulking gun :)
  • Ted_9
    Ted_9 Member Posts: 1,718
    8:00 am and 6.6 degrees out side
    Indoor reset 1st floor is 68 2nd floor in the mid 70's, with 164 degree water. That's with 3 rooms next to the indoor sensor without heat.
    Massachusetts
  • Ernie
    Ernie Member Posts: 94
    Mine
    Its 10*F,boiler just hit 167 *F I will not let it go higher. All baseboard convectors,downstairs 73*F,upstairs the same. Location lower Fairfield County , CT
  • Brad White_9
    Brad White_9 Member Posts: 2,440
    Southwest part of Boston
    it was an even zero this AM, about 5:45. My Monitor MZ was 140*. House was trying to catch up (66 heading to 68 which it should have reached at 5:00 ("Legal" outdoor design by code is 7*).
    May be time to re-set the curve? Eh- I am doing just fine.
  • TONY_22
    TONY_22 Member Posts: 28
    6deg avg outside here last 24 hours
    My boiler temp was about 212deg, give or take, and the boiler ran for 7.5 hours out of the last 24 (just a little oversized). I like my steam, but I do get mod/com envy at times like these.
  • Xc8p2dC_2
    Xc8p2dC_2 Member Posts: 150
    Smiling in comfort
    With an Ulta80,, 6am this morn was 4 degF,,, 140 kept me good at 70 in the 3 beds zone, but a little lacking in the kitch/liv zone [home is 1325 sq with 88 ft fintube]
    Bumped water temp up to 150f, but more importantly, bumped back gas input to 32K btuh max and still able to overshoot tstat.. looks like the sweet spot
  • Al Corelli_2
    Al Corelli_2 Member Posts: 395
    6 degrees this AM
    Primary radiant at 128, mostly joist bay with plates. Dunkirk not even breaking a sweat (unless you count condensing!) Engineered wood floor temps are at 78-83 degrees. Thermostat shows 67 in bedrooms (at setpoint) and first floor at 68 (also at setpoint). Boiler is NOT running constantly. I guess at 90k btu, it is still a little oversized. That's OK, the snowmelt hasn't run yet this year.
    Secondary Baseboard has not kicked in yet. And this is with nasty old windows. I figured with the old windows, I would not have to install an HRV/ERV thing. :)
    Maybe I wasted my money on the two stage system?
  • Uni R_3
    Uni R_3 Member Posts: 299
    At 8am...
    Thanks for the surprise quizz! ;-)
    OAT 4
    BST 134
    BRT 126
    IAT 72+
  • 10°F Outside
    Was about 10°F outside at 7 am this morning here in Wakefield and the "Old Blue" Burnham MPO was heating the house very comfortably at 143°F this morning without condensing with a standard Tekmar Reset Control. In fact in the nearly 2 years of time I have had this installed the hottest Heating Supply water I have seen has been 147°F. System efficiency is alive and well in my little corner of the state.
    Glenn Stanton
    Manager of Training
    Burnham Hydronics
    U.S. Boiler Co., Inc.
  • CC.Rob_2
    CC.Rob_2 Member Posts: 46
    but what is the design water temp?
    test
  • Chris_82
    Chris_82 Member Posts: 321
    Had to turn it on,...
    Salem NH, had to turn one of the tstats up to see what it would run at. I know it came on about 1 am once during the night, but it being a sunny day it hadn't turned on as of yet, the VRVP heating edge is running at 80, it ran for about an hour, till I shut it off, opressive at 80. Fully modulating ultra directly feeding 160 gallons of "tank within a tank" as the primary loop set at 90, no other controls, secondary loops run off individual t'stats. Individual, arggh, munchkin heating 120 gallon SS, set to 180, with a custom Powers aqua controller with a set point span of 50 degrees, with a sparco/Leonard mix down to 100 for domestic, 125 for kitchen, hasen't come on in the last day or so. When I retired I just started playing with stuff to max out the efficiencys and adding insulation to the attic and such. Attic currently has 28 inches of insulation as an example.
  • Mike T., Swampeast MO
    Mike T., Swampeast MO Member Posts: 6,928
    25°F outside.
    92°F supply temp.
    94°F flue temp.
    81°F return temp.
    Boiler kicked out of modulation at about 10:40 a.m. with an outside temp of about 40°F. Clear night and very sunny day.
  • Ragu_5
    Ragu_5 Member Posts: 315
    Reporting In....
    Vitodens in a commercial radiant slab; 100'x50' insulated steel building in Maine. Mostly a workshop area at the moment, so they want the indoor temp@ 61 F.
    Outdoor was -4 F.
    Indoor air temp was 61 F.
    Supply was 82 F.
    Return was 72 F.
    What do do guys think? I am definitely no Einstein! Thanks.
  • Brad White_9
    Brilliant, Jack
    What do you mean you're no Einstein?
    You are meeting setpoint with a perfect 10 degree delta-T, you probably have room for more output (you definitely do) and you have a happy client.
    Einstein, on the other hand, has been gone for 52 years and has his brain in a jar somwhere in Princeton.
    So...which would you rather have for yourself? ;)
    You rock.
  • Ragu_5
    Brad....
    I'm sorry that we have missed each other in person on my past trips to Bean Town; however, when we meet in person, you are going to get a big smooch on your noggin. Thanks! Jack.
  • Jamie_6
    Jamie_6 Member Posts: 710
    Had to head out to work @ 5:30 this morning and ran downstairs to check also. (Glad to see I'm not the only crazy one out there!)
    My GB was rockin @ 134 degrees, the house was holding strong @ 70 & it was 10 degrees outside. God I love radiant!!!!!!!!
  • J.C.A._3
    J.C.A._3 Member Posts: 2,980
    I'm.....
    Too flipping tired to check my boiler temps. It's 3° and my place is at 65°...I don't even CARE at this point!
    Can you tell I've been dealing with freeze-ups and boneheaded people all day? Life moves forward, I just ain't seeing broken pipes....so I'm O.K. Chris
  • A.J.
    A.J. Member Posts: 257
    Mine
    Buderus G115
    Taco PC 705 injection controller was maintaining boiler temp @ 149 F, mix temp was holding around 137 F feeding my cast iron base. That was when I left for the first call of the day at 5:30 AM with a outside temp of 7 F and the house not moving from 72 F, Johnstown Pa.
  • bob_50
    bob_50 Member Posts: 306
    Isn't supply temperature
    a function of emiter output vs heat loss? I don't see how the boiler has much to do with it unless it's under sized.
  • Christian Egli_2
    Christian Egli_2 Member Posts: 812
    Supply 212F Return 212F Duh!
    There is more to life than numbers and how hot water compares to steam, but I don't know any better. :)
    To expand a bit on BC's numbers, he was at 212F for 7.5 hours, while the rest of the time the steam was flat. Stone cold radiators. (Note how this is drastically different from what hot water is - Most have posted water temperatures of above 100F, which in constant circulation, will have presumably been kept that hot all day long)
    While steam comes at 212F, this is not the average system supply temperature; oppositely, hot water supply temperatures are (within a bracket) the average values. Can we compare apples to oranges? Yes we can.
    BC's system ran for 7.5 hours. In his whole day, there were yet another 16.5 hours that ran cold, and steam goes cold and flat within minutes (this is a source of great efficiencies). We can now compute the average system temperature for BC's system, let's guess his home is at 68F (radiators under draughty windows would be colder yet).
    (212F * 7.5h + 68F * 16.5h) / 24h = 113F weighted average
    113F averaged supply temperature for steam is surprisingly low considering BC lives somewhere where it was only 6F. In comparison, Al also at 6F, reported 128F. (Technically, this 128 is more of an instantaneous morning number, and I'd expect the average supply temperature for the whole day to be lower, possibly 113, who knows)
    Steam heat grabs you by the lapel, gets you out of bed in the morning and shakes you until you're cooked. You feel the heat and it's addictive. At 113F, it certainly isn't crazy at all, just different.
    What is modulated in a temperature space in a modern hot water reset is equally modulated in a time field for hot air and especially hot steam. Same difference.
    Was this a good splash or what?
  • Weezbo
    Weezbo Member Posts: 6,231
    - 24 °F
    74-40 indoor temps, depending on the zone.
    128 boiler temps.
    and steady return mixed temps...of 120 ish :)
    the reality though is, if i send 167 out i will see over 95 delta t mixed return with no by pass at the boiler.
    this Slantfin Intrepid is one Tough piece of iron:))
  • Phil_6
    Phil_6 Member Posts: 210
    Friday AM
    Since I'm nuts like everyone else here, I take a look every morning.
    6 AM
    Monitor MZ
    9 Degrees OT
    160 water temp
    72 inside
    Thats the highest the temperature has been in at least 2 years. And their was heat to spare. Maybe I'll turn it down a little. Just for kicks.
  • Brad White
    Brad White Member Posts: 2,399
    Christian, you are wthout a doubt
    one of the very good reasons I come here.
    Thank you for lending us your eloquent brain!
    Brad
    "If you do not know the answer, say, "I do not know the answer", and you will be correct!"
    -Ernie White, my Dad
  • Brad White
    Weezbo-
    I have a 40 degree zone in my house too, but I call it "my refrigerator" :)
    So, you heat your refrigerator with radiant to keep the milk from freezing?
    I have to imagine at -24 and you let the dog out, you had better check to make sure he is not frozen to the hydrant :)
    Some years ago the weather forcaster on a local radio station stated that in parts of NE that night, "the mercury would drop to 40 below..."
    Naturally, I called up to take exception because mercury freezes at about 38 below.... He managed to get out the word "smart@ss!" before slamming down the phone in my ear.
    I guess cold makes people grouchy :)
  • Perry_3
    Perry_3 Member Posts: 498
    Today...
    Today 26 F outside.
    Vitodens is currently cycled off as even at minimum fire it is oversized for much of the year (at least for the indoor temps I maintain) - even at 26 F outdoor.
    Current loop return & supply temperature is 110 F
    Radiators are warm and House is comphy at 66 F
    Yesturday it was in the 12 to 13 F range where the Vitodens could just purr at miminum fire rate (or just over minimum fire rate). Boiler outlet was at 135, LLH outlet was 130 F, return temp at 125 F, House was comphy at 66 F.
    Yipee ! It works.
    Perry
  • McKern
    McKern Member Posts: 71
    Mr Egli
    So the boiler starts at 68° and returns to 68° within seconds after the heat call ends? Amazing!!! ;-)
  • near zero today
    and my boiler is about 65 degrees, it has been off for two years. I'm heating with solar and a wood stove. I recently installed radiant in the walls and ceiling near the wood stove and I recirculate it to move the heat from the wood stove room to the cold part of the house. This method also helps store the heat in the floors and walls the result is lower temperature swings. 70 degrees in the house last night, and 60 when I woke up this morning without feeding the wood stove over night. President Bush says we are addicted to oil, well I have been off the oil for 2 years, can I get a 2 year chip, like they give at AA? Bob Gagnon
  • clammy
    clammy Member Posts: 3,251
    9 outside
    it was 9 degrees yesterday morn when i was leaving home ,my munchkin t80 was running at about 135 keeping my home at 69 with all slant fin 30 and some staple up radiant (4 -180 loops onixon)Yet to get a gas bill yet since i put the new boiler and have been home but last months was about 40 bucks less with the house staying at 68 and the indirect maintaning temp but no one was home .Low water temps rule .peace and good luck clammy
    R.A. Calmbacher L.L.C. HVAC
    NJ Master HVAC Lic.
    Mahwah, NJ
  • Patchogue Phil_29
    Patchogue Phil_29 Member Posts: 120
    oil usuage
    Constantin
    What is your setup to measure how much oil you have used?
  • Chris_82
    Good man! If I could turn this house 90 degrees I would, but I can't. The real bummer is that the neigbors trees, over 90 feet high, keep me in the shade. Solar only works for a couple of hours. When I craok some one is going to get a really well insulated house though!
  • Weezbo
    We Lousy with COLD ,Here Brad*~/:)
    that same room is 51 today :)
    that makes 19000 sq ft of radiant with 90% of it in the high 60 or better and one sliver of about1200' at 51 :) give a guy a break:) i have been the control over this thing from the gate:) did i mention this room is having 58 degree water rolling since day before yesterday:)
    You certainly have some valid point though about the 40 degree zone:)
    my buddy stopped by the shop this evening and goes..".Hmmmm....so what are you Really firing that 3 section Slant-Fin Intrepid at?" "1.75?" "nope" a 1.1 :)
    I would like to personally thank You and Mike for your prayer that i would see some vapor barrier and insulation in the walls and ceiling. Thank everyone else for the help too. your thoughts helped make it happen:)
  • Christian Egli_2
    Oh, I leave for a day, and I'm already missed
    Building a full head of steam makes my head swell to unbelievable dimensions. Thanks Brad for making it no longer fit through the doorway... Thanks for the heartfelt word.
    Now, for some bubble busting... The system fluid in a steam heated place does not go from 212F to 68F in mere minutes... I lied... I exaggerated... it all happens within seconds. Seconds. (of which there can only be as many as 60 in a minute)
    Here is how it works.
    Let's talk about a one pipe system with vents at the radiators - just because it is easier to visualize, but it's the same in any steam system. Turn it on.
    We have the boiler putting out a cloud of steam, which, like the storm front on the weather channel, it advances and retreats on the mere whims of the jet stream, el Nino or even the command of a global thermostat.
    In home heating, this cloud advances only within the confined boundaries of our cast iron radiators. The cloud, or more technically the space occupied by the cloud, is our heating medium and it comes in only two very specific configurations. Nothing in between.
    The cloud of condensing steam is very obviously at 212F, and although steam particles within it travel at about sixty gazillion miles per hour, the cloud itself only lumbers down the pipes at a rushed pace. Stop the heat, and the cloud shrinks in the opposite direction at about the same rushed pace.
    What replaces the cloud when it collapses out of the way? You know exactly how this happens: the vent reopens and re-supplies the pipe innards with atmospheric air taken at room temperature, at thus 68F. The radiator retreat, which only lasts the time of one pace leaves behind it an emptiness filled with cold air. The heating fluid which comes in the shape of the moving cloud goes from 212F to 68F in mere instants.
    Try it out at home. Boil yourself a cup of tea while playing with the kettle. Full flame - full steam plume. Turn the gas fire off and the whistling stops on the spot. Steam goes away in seconds, there is no waiting for inertia. The concept is so powerful, there is (or used to be) a commercial that emphasizes a quick acting cold relief medicine by flaunting a steaming tea kettle. Flu - gone like the wheezing plume - quick - as seen on TV.
    Of course the next post will claim that the cast iron itself, of which the system components are made of, will not change temperature while we stare impatiently at the watch. That's true. But heating and cooling goes both ways and whatever time it takes to warm up - gets returned upon cooling. More or less the same delay and whatever it is, it's not a concern for studying internal fluid temperatures of either water or steam systems. 7.5 hours of steam shortened by 10 minutes of warm up time and lengthened by 10 minutes of cooling time is still 7.5 hours. Baffling.
    Fluid temperature is all we were concerned about in this thread. Hot water in one case, a hot and cold cloudy space sometimes filled with steam in this particular case.
    Interestingly and surprisingly, the average supply temperatures are the same for steam or hot water leaving us with no sledge hammer argument to go convert the world.
    Pshhh.
    I've got more... can I go on a bit?
    The race to the coldest fluid temperature is held as the holy grail of efficiency, but is it? [In thermodynamics book stuff only the opposite is true]
    If it truly were the key to system wide heating efficiency, then the most boring forced air furnace should always win out - it does suck in air at the lower ranges of indoor temperature; this is far colder than any returning water can ever dream of; the same mostly holds true for supply side temperature. Steam does not play this game.
    So, this is the question now: Do we know forced air systems to be by default always more efficient than a hydronic one? If low temp water is, when compared to steam, then it must be further true that lower temp air is too, in comparison to water.
    Cough cough, I need some of that cold therapy I was advertising earlier.
    The cold source temperature argument holds true in one fashion. Greater heating efficiency and economy is gained by lowering the indoor thermostat to the lowest lower possible low setting. Weezbo's 40F indoor relative to -27F in Alaska seems very balmy indeed.
  • BC_3
    BC_3 Member Posts: 12
    Christian - check the steam efficiency thread
    I had some comments on this and specifics of my system and I copied your post to a new thread - I hope you don't mind, I didn't want it to get buried in here.
  • 150 DEGREES f..
    Same as its been all winter long...
    ME
  • Ron Gillen
    Ron Gillen Member Posts: 124
    Cool breese this morning
    Edmonton,Alberta
    23F
    Vitodens 98F
    HCA 92F Supply 85F Return (Main Floor)
    HCB 74F Supply 70F Return (Basement)
    Comfortable 70F Room Temps
  • Brad White
    Bob
    I think your point makes sense in part and particularly when a system settles to equilibrium. It is definitely part of the equation, no doubt! More emitter to heat loss and the lower the temperature as you know well.
    Most of these posts are based on outdoor reset as you can imagine, so the marvelling is about how close the boiler is producing supply temperatures which are tracking design intent.
    The other part is, some systems such as the Vitodens, jump off the programmed curve apparently, favoring longer burn times at lower input to still meet setpoint.
    Can anyone imagine a time in history when low water supply temperatures confer bragging rights? :)
    I love this age!
  • In the GOOD old days...
    If'n the Gore family had invented the internet back around the first of the century (1900's, NOT 2000) we be bragging about how little coal our systems used... I can hear it now, "Only used 5 scuttles full in 24 hours, and I DIDN'T have to haul ANY ashes... Top That!!"
    Now, we sit around bragging about how the utility company is freaking out every time we install a mod con appliance that causes their meters to nearly stop, and in some cases, almost run backwards ;-)
    Most utility companies have a software program called a WatchDog notifier. If the consumption deviates by more than 25% from the previous year, the meter shop is notified that there may be a metering issue in the field. Their intent is two fold. The first is to catch the end user possibly bypassing the metering system, adn the other, if the first doesn't prove TRUE is to replace the meter because it is hanging up and under registering. In either case, they're worried about someone elses hand in their pocket...
    Heck, 5 years ago we couldn't do with the boilers what we are doing with them today....
    You're right Brad, these ARE some pretty exciting times we are living in...
    ME
  • Chris
    My roof is oriented east and west too, but I built my collector array over a deck. I also had the same problem with my neighbors tree, but they let me cut it down when I told them what I wanted to do. Bob Gagnon
