Whats your boiler water temp this morning?
The WEL...
... I have a non-contact current switch on the burner that records whenever the burner is running.
Combine that with a known flow rate (0.96gph) and you have consumption (yeah yeah, I know the pre-/post-purge is skewing those results but I cannot be bothered, this is close enough)0 -
10F outside
supply 95F
return 82F
floor 73F
room eye level 67F
stand alone 20 gal HWT, 325 sq ft radiant plus a little wall.0 -
7° F outside
Coldest yet this year. Hydro-air system: 40 year old American standard boiler supplying a coil in a Trane Climate Changer airhandler. House is 70°, boiler supply temp is 136° F. Air blowing from registers is toasty. Looks like a modcon boiler would still be condensing, right?0 -
Coldest yet
6:00 am this morning
OAT: -1 deg
SWT: 128 deg
RWT: 102 deg
indoor temp: 69 deg
My T-80 cranking along at about 75%
Two zones of Onix staple-up
One concrete zone
j
