recurculating pumps
jmills
Member Posts: 1
I have a gas fired boiler, currently the recurculation pump is on the return side, i have been told that the system will operate better if the pump is on the feed side, is this true, and is there any other changes that need to be made for this to work?
Thanks
Jeff
Thanks
Jeff
Pump Away
Check out the store on this site, purchase a book by Dan call "Pumping Away". Easy read and will give you all the reasons you need to change your system.
Peace
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"There was an error rendering this rich post.
language
Why does a hydronic system have a circulating loop but a domestic loop have a recirculating loop?0 -
I was told to pump from highest volumne of water to lowest
volume of water check the spec's of the manufacturer where they want the pumps0 -
dblpost
