Geo units on cooling tower
ddlong1286@yahoo.com
Member Posts: 139
Hello,
A question on the current setup at work. We have geo units on a loop with a cooling tower. In winter we have a steam to hot water converter to provide heat to the loop. In summer the tower.
My question is the way they add water and glycol. There is a tank with a site glass that is isolated from the loop when water and glycol is added. After adding the liquids, air is added to boost the pressure above 20 lbs. The system has an air seperator and air vents at the highest point of the system and a bladder tank for expansion. Will not the air elimanators work at removing the air in the "fill" tank? Don't I want to add water pressure to boost system pressure?
I will try to get pics monday, will probably make more sense when you see it. Just does not make sense the way it is set up.
Just started at the college here in April so have not experianced this system at work in extremes.
Thanks
Don in MO
Thanks
Don in MO
If you have a cooling tower you have a heat exchanger in the loop for the tower, if not you would have glycol in the tower also.
Most likely the pressure you are adding to the system is on the building loop, just like maintaining pressure on a boiler. The air remains in the expansion tank and may even have a blader between the air and glycol.0 -
we maintain a similar system
and the system has a b&g scrubber also, but we don't chase any additions with air pressure. we use a pump that has enough pressure to overcome the system pressure0
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 994 Plumbing
- 391 Solar
- 55 Water Quality
