Steam heat benefits
Jamie Hall
Jamie Hall Member Posts: 26,169
to accumulate quite a list by the time we are through!
Quiet
No moving parts
Low maintenance
Even heat (assuming you have it set up right!)
Steady heat
Simple
For starters...
  • Glen_7
    Glen_7 Member Posts: 82
    We have a 95 year old house that is 9,500 sq/ft. It has one pipe steam and we replaced the boiler and some near boiler piping last year. It is working perfectly. The reason for the post is that I have the house for sale, and would like to be able to explain in lay terms why steam heat works best in a home like this. People have inquired about why we didn't just convert to h/w or hydro when we installed the central air. I explained about the comfort, etc. but would like to know what you pros would say. Thanks.
  • Steamhead (in transit)
    Steamhead (in transit) Member Posts: 6,688
    Comfort and efficiency
    most people don't know the typical duct system loses 20% of what goes into it. That's how the scorched-air and heat-pump pushers get away with it.
    Also the radiators heat the rooms without blowing air around- moving air makes you feel cooler. And they don't harbor mold or other nasties like you find inside ducts.
  • Kool Rod
    Kool Rod Member Posts: 175
    You might want to casually mention that steam heating works on very low pressure. I have an old house with an old one pipe steam system (new boiler) and have been asked several times if I didn't worry about such an old system being weak and blowing up. I guess that a lot of people equate the word "steam" with locomotives and naval destroyers.
  • JJ_4
    JJ_4 Member Posts: 146
    Moisture in the winter?
    My wife claims that her skin isn't as dry in the winter as when we lived in a house with scorched-air. I am guessing that some moisture comes out when the radiators vent air at the beginning of the cycle. We haven't had to have a humidifier while living with our steam.
    Plus, sitting near a radiator in the winter is like sitting by a fireplace. No better place to sit and read a book.
  • Scorched Air is Dry
    Because it blows the air around and evaporates the moisture off your skin. The heat you feel off a radiator or fireplace, is radiant heat, that's why it is so comfortable.
    Thanks, Bob Gagnon
  • jimmac
    jimmac Member Posts: 52
    dont forget
    don't forget with a house the size of yours..if the heat should not work in the coldest of days you will not freeze your radiators or pipes..
    it would also have to bring the house to a more comfortable temp faster that hot water...if it had comparable piping
  • Rich Kontny_3
    Rich Kontny_3 Member Posts: 561
    Cleaner
    Indoor Air Quality is better with wet heat. No scorced air particles blowing around
  • Larry C_13
    Larry C_13 Member Posts: 94
    Less Electrical consumption
    You also have less electrical consumption because of no water circulating pumps or fans.
  • Low power requirements benefit
    A battery backup with 24 volt inverter/charger will keep the steamer going for many days during power outages.
    24 volt inverter/chargers are readily available. You could use 12 volt battery sets but 24 vdc systems are more efficient.
