rad valve on side
Timco
Timco Member Posts: 3,040
No problemo...
Tim
Just a guy running some pipes.
  • AJ5
    AJ5 Member Posts: 3
    Any problems installing an angled radiator valve on it's side rather than the typical upright position? The pipe comes out of wall at the level of the bottom rad. inlet and would turn 90 degrees via the valve and into the radiator. The handle would stick 'out' instead of 'up'. Looks not important. Thanks
  • bob young
    bob young Member Posts: 2,177
    CONSIDERED NORMAL PIPING PROCEDURE
