rad valve on side
Timco
Member Posts: 3,040
No problemo...
Tim
Tim
Any problems installing an angled radiator valve on it's side rather than the typical upright position? The pipe comes out of wall at the level of the bottom rad. inlet and would turn 90 degrees via the valve and into the radiator. The handle would stick 'out' instead of 'up'. Looks not important. Thanks0 -
CONSIDERED NORMAL PIPING PROCEDURE0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
