Propress and Fitting adapters
singh
singh Member Posts: 866
crimped a 1" coupling onto the manifold adapter many times, no problems yet.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=377&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • scott markle_2
    scott markle_2 Member Posts: 611
    propress and Fitting adapters
    Does any one have an experience pressing to Uponor manifold adapters. Uponor makes a manifold that is 3/4'' on the inside and 1'' fitting adapter on the outside The brass is thick to make up the difference in size.
    I recently did some press connections to this fitting and they seem to be leaking ever so slightly, The tool did seem to groan a bit making those connections and I had some concerns about the thickness of the brass creating a problem. any thoughts? Should I repress and hope for the best or just accept this is a misapplication and re-pipe.
  • Pinball
    Pinball Member Posts: 249
    It works
    We have done this a number of times and so far it seems to work.
    No leaks yet
    Al
  • scott markle_2
    Thanks for the input. I'm fairly certain I have a bit of seepage, it's evaporating before it forms a drip but I can smell the distinctive Rhomar inhibitor when I place my nose close to the fitting.
    If you guys were going to repress a fitting, would you place the the jaws in the original orientation or rotate it so the pinch points are in a new location?
    Thanks, Scott
  • EJW_3
    EJW_3 Member Posts: 69
    Pro Press
    If it was me I would put the jaw on the fitting in the exact same place and press again. Dont know if I would have the stones to try it the other way. :)
    EJW
