Propress and Fitting adapters
singh
Member Posts: 866
crimped a 1" coupling onto the manifold adapter many times, no problems yet.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=377&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
propress and Fitting adapters
Does any one have an experience pressing to Uponor manifold adapters. Uponor makes a manifold that is 3/4'' on the inside and 1'' fitting adapter on the outside The brass is thick to make up the difference in size.
I recently did some press connections to this fitting and they seem to be leaking ever so slightly, The tool did seem to groan a bit making those connections and I had some concerns about the thickness of the brass creating a problem. any thoughts? Should I repress and hope for the best or just accept this is a misapplication and re-pipe.0 -
It works
We have done this a number of times and so far it seems to work.
No leaks yet
Al0 -
Thanks for the input. I'm fairly certain I have a bit of seepage, it's evaporating before it forms a drip but I can smell the distinctive Rhomar inhibitor when I place my nose close to the fitting.
If you guys were going to repress a fitting, would you place the the jaws in the original orientation or rotate it so the pinch points are in a new location?
Thanks, Scott0 -
Pro Press
If it was me I would put the jaw on the fitting in the exact same place and press again. Dont know if I would have the stones to try it the other way.
EJW0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
