which radiator vents are best?
Tim_64
Member Posts: 76
and have my system so I get heat through all rads in 15 minutes
i.e. heat at the rad valves in 7 min
just want some rad vents that don't suck.
Home Despot continues to disappoint me... I really don't know why I still go there
That is the question.
I replaced all my main and radiator vents after the install of my new boiler this past summer. Mains are combinations of Gorton 1's and 2's no problems there...
I got all the radiator vents from Home Despot... they sell the "Maid-O-Mist" line... these to me, like much of the stuff they sell in Home Despot are pieces of crap. Especially since I dissected one of the failed vents and found the float to be made of some really cheap plastic that crumbled in my hand.
I have had some not work right out of the box, and others that last only a few steam cycles.
Yes these are installed on a long neglected steam system, so a lot of crap migrates to the vents.. I expected some to fail..not 50%
So which are the heavyweights in the vent world? the indestructos?
Are the Gorton 4,5,6,c,d, same as Maid-O-Mist 4,5,6,c,d?
How about Hoffman vents?
I'd really like to find one that is all metal construction, like the Ventrite, which I removed, cleaned and still have ;-)
So any pros who have read through this... which brand has the least call backs?
TIA and a good thanksgiving to all
Tim0 -
Gorton
and varivalve.
Go to the Gorton website to get instructions on what goes where...kpc0 -
drywall screws???
about it. Maid o' mist valves look similar to the gorton but as you know the guts a very cheap....hmm. kind of like there faucets. look like name brands but inside are cheap knock offs. kpc0 -
Hoffman #1A0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 851 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
