becket burners
Ken D.
Ken D. Member Posts: 836
Check for fuel delivery problems. Dirty filter, pump strainer, oil line, etc. Leaking oil line fittings. Too many elbows or oil line length. High vacuum can cause oil to gasify. Cold oil can give ignition problems. Hope this helps.
  • ed_42
    ed_42 Member Posts: 1
    becket burner
    i have a becket af burner that locks out occaisionally. the control, nozzle, cad cell, trans, all new. oil press good. all set per specs
  • gary_6
    gary_6 Member Posts: 60
    Could be a number of things.. I know you came here looking for an answer but it might be best to call a heating tech.
  • Ragu_5
    Ragu_5 Member Posts: 315
  • Ed N.Y.C.
    Ed N.Y.C. Member Posts: 73
    Beckett
    Check the motor and plastic coupling ends ED
  • Darrell
    Darrell Member Posts: 303
    The new burners are so tightly designed that some times the cad cell doesn't get a good "picture" of the flame...so anything that makes the flame go burp will push it into lockout. Dirt, dust, cat hair, poor oil quality, sustained positive overfire draft, sustained negative overfire draft, etc... As the other gent said, electrical nonsense and stray electrons will also cause the protectorelay to lock out. Make good notes on everything you can think of relating to the current conditions when the nuisance lockout occurs and that will be a huge help to the serviceman.
