snow melt controls
carol_3
Member Posts: 397
I'll be out until Friday this week.
snowmelt controls
what is an easy and simple way to control a snowmelt sysem. the area in question is a concrete walkway about 200 square feet? thanks0 -
a Tekmar 650 snow melt control set to melt upon power up. Install a manual on/off switch in a suitable location and just turn it on when you want it. The control is basically an idle control but it is a low cost option. I have used a switching relay and a remote located snow sensor such as a ETI but have had problems with repeated sensor failures. If you're willing to spend the money, a tekmar 664 (or similar) with snow/ice detector is the way to go for automation.
For such a small area, I'm guessing you don't want to spend a ton of money. Just ensure you provide thermal protection for the boiler unless it is rated for low return temps.0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 112 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
