Radiator Vent location
Al Letellier_9
Member Posts: 929
One a one pipe system, the vent should be located on the opposite end of the rad from the valve and about 1/3 to 1/2 of the way up. If there is a plug there, you probably won't get it out and will have to drill it out. I use a grinder to get the plug flat, **** punch the center and drill it out. It would be adventageous to have a 1/8" NPT tap to chase the threads.
Vent location?
Hi, just a few questions before I just order new vents and have someone over to re-vent my radiators.
I have some radiators with vents on the top instead of near the middle(and some apparently on the wrong side?) Thing is, I can see the plugs on some of the radiators ON the valve side.
Would the wplacements of the vents cause hammering or cause the boiler to short cycle? I know it causes uneven heating.
Last question: I seem to have trouble removing the plugs so I can place the vent there. What tools do I need?
Thank you in advance
So I presume the placement of the vents have nothing or little to do with any hammering?0
- 87.1K THE MAIN WALL
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
