ELECTRIC WATER HEATER
FATBOY040575
FATBOY040575 Member Posts: 17
The 1" outlet may be a hard one to find, I know that State makes on (ES6 6 SOMS) but this unit only has a 3/4" outlet.
  • bob eck
    bob eck Member Posts: 930
    Anyone know if there is a electric water heater on the market 10 or 15 or 20 gallon model with a 1" inlet and outlet?
  • Jed_2
    Jed_2 Member Posts: 781
    Just put
    1"x3/4" cma and you'll be fine. Trying to imagine the application, though.
    Jed
    hot_rod Member Posts: 26,592
    sure, if
    you remove the elements! If not a couple bell reducers would provide 1" connections.
    Bock has some insulated storage tanks, 20 gallon with 1" connections.
    www.bockwaterheaters.com/Products/Product_pdfs/80022_Storage_Tanks_9-07.pdf
    hr
  • bob eck
    Hi
    The job is going to have two NORITZ N0751M or two N0931M tankless gas water heaters tied together and then dump them into a 10 or 15 or 20 gallon electric water heater then go to the house fixtuers and then run a 1/2" return line back to the electric water heater where there will be a GRUNDFOS domestic hot water recirculation pump on the small electric water heater this way when using a recirculation pump on tankless gas water heaters I will not be recirculating the water through the tankless units. I know with noritz units if you recirculate thorugh their tankless water heater the warranty on the heat exchanger goes from 10 years down to 3 years and I want the home owner to keep the 10 year warranty on the heat exchanger and all the samll electric water heaters are tapped with 3/4" and when installing two noritz units together noritz wants them piped with 1" and I was told that the 3/4" tappings on the electric water heater will reduce the flow from both Noritz units when both are running at the same time.
  • jp_2
    jp_2 Member Posts: 1,935
    parallel?
    whats the volume of your hot water lines?
    I might think of an ele tank 2-3X pipe volume.
    I would think about piping the ele tanks in parallel very close to the output of the on-demands. do not see the need for series connections. make it act more like an expansion tank with the recirc line on its supply.
