Burnham V83
John@Reliable_14
Member Posts: 171
if set-up properly.
Burnham V83 conversion
I have a customer that has a Burnham V83WBT oil fired boiler w/ tankless, installed by his oil company a few years ago. He now wants me to install a gas conversion burner on this boiler. He has a gas service to the house and a lined chimney.
Other than the normal effiency reduction issue, can this be done, and what brand conversion burner would you recommend?0 -
No...
just put a riello burner on that boiler and no more soot, no more problems... Riello burns real clean...0 -
Well it depends...........
whats common in your area, as far as parts? I like the one from Carlin, easy set up. But it may be wise to have oil burner set-up properly for $avings with oil.0 -
I would look @ the BTU price of NG & oil then the cost of converting If you have a Burnham V83 sooting Its not set up right They burn clean
Ed Kuk0 -
Never said
Steve never said it was sooting up. Where do you get that?0 -
Your right He didn't say it was sooting I read to much last nite When Steve said install a Ratela burner & on more soot I got confues W/ another.
Sorry Ed Kuk0 -
Your right He didn't say it was sooting I read to much last nite When Steve said install a Ratela burner & no more soot I got confued W/ another.
Sorry Ed Kuk0
- 85.7K THE MAIN WALL
- 50 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 852 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
