Steam bolier dirty water
jim_121
jim_121 Member Posts: 1
Just moved into a house with a steam boiler.
Last nite the boiler shut down due to low water level. I added more, but now the water visible in the glass sight is yellow/brown instead of clear as before. Also, the water level is bouncing up and down - any ideas?
Thanks
  • Al Letellier_9
    Al Letellier_9 Member Posts: 929
    dirty water
    You diagnosed the problem, Jim. The boiler probably could use a good skimming and treatment to clean up the water. A good steam pro can do this for you at reasonable cost.
