Steam bolier dirty water
jim_121
Member Posts: 1
Just moved into a house with a steam boiler.
Last nite the boiler shut down due to low water level. I added more, but now the water visible in the glass sight is yellow/brown instead of clear as before. Also, the water level is bouncing up and down - any ideas?
dirty water
You diagnosed the problem, Jim. The boiler probably could use a good skimming and treatment to clean up the water. A good steam pro can do this for you at reasonable cost.0
- 86K THE MAIN WALL
- 52 Biomass
- 420 Carbon Monoxide Awareness
- 80 Chimneys & Flues
- 5.3K Gas Heating
- 95 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 888 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
