cooling load and duct sizing
Carrier has a nice program in REZCALC. Easy to use. Good tech support.
  • ddenny
    ddenny Member Posts: 75
    hello professor
    any recommendations for cooling load software?
    I was also looking for a way to learn the how tos of duct sizing and a distribution for hvac systems. maybe a seminar. thankyou
    dennis carroll
  • Empire_2
    Empire_2 Member Posts: 2,340
    Denis
    Try Manual J and D available through ACCA.com If you prefer PC work, use Right J and D software. Also, Invest in a good ductulator... You can play with different duct sizes and it will help you in your work.
    Mike T.
  • pat renz
    pat renz Member Posts: 4
    software
    hvac-calc 4.0
  • Eugene Silberstein 3
    Eugene Silberstein 3 Member Posts: 1,380
    For residential
    Greeutings Denis,
    For residential applications, your best bets are Manuals J and D. Although more time consuming to perform, I am partial to the Manual D method and this is what I teach at the college.
    As far as seminars go, there will likely be some Manual D and Manual J sessions coming to a Long Island near you.
    Will keep you posted.
