Failure!
Larry Weingarten
Larry Weingarten Member Posts: 4,010
You do the work, suffer the pain and cost ... and we all benefit from the lessons learned! What a deal :~) I am curious to know how the Navien performs and holds up, as it looks like it could be good technology.
Thanks!
Yours, Larry
  • Rich Kontny_3
    Rich Kontny_3 Member Posts: 561
    A Failure!
    After 18 months with a demo unit hooked up to a"Heating Box" on an experimental basis I have indeed encountered a failure with the heat exchanger on the Takagi T-KD20 I will be returning it for it's autopsy. I see a great deal of corrosion on the top of the copper finned XH and suspect that is the problem.
    This was a test unit with only my labor and materials as my cost. I will probaly go to the Navien high efficiency unit as my next test model.
    Stay tuned!
    Rich K.
  • Rich Kontny_3
    Trial and Error
    Larry,
    This unit was exposed to some very tough conditions. Weather extremes outside from -10 to 100 (this creates differnt levels of condensate as the stainless vent really conducts cold to the top of the unit). The "Heating Box" add-on while hooked to a well insulated in floor zone does cause more cycling of the unit.
    The other test system has a Rinnai Continum Tankless with a plastic outer sleeve and stainless interior exhaust
    pipe. This seems to be working fine and the in-floor is a fairly large garage for a landscaper who stores his snowplows etc in there. Thus far he has had zero problems (knock on wood)
    I know you are very well versed on hot water systems and I posted this for that reason. I was a little disappointed yet not entirely surprised as I also have very hard water that I bring down with a softener yet that is still not the most desirable for a tankless.
    I tend to push things instaed of babying them. I want customers to have durable and reliable equipment.
    Thanks Larry, you and your wife are assets to the industry.
    Rich K.
  • Derheatmeister
    Derheatmeister Member Posts: 1,659
    Open system?
    Is this a system that uses domestic waterheaters as a heatsource? And does it also supply the domestic hot water on the same system?(Interconnection)
  • Rich Kontny_3
    Closed System
    Der Heat... they offer the open system but I would not do that so I used their closed system. It is a packaged unit "the Heating Box" by Navien America. I have used both the Takagi and a Rinnai for heatsources on the two test systems I set up.I am kind of glad I was the one who had the failure not my friends son. Although he knows the situation and wanted to try this new heat source concept.
