Failure!
Larry Weingarten
Member Posts: 4,006
You do the work, suffer the pain and cost ... and we all benefit from the lessons learned! What a deal :~) I am curious to know how the Navien performs and holds up, as it looks like it could be good technology.
Thanks!
Yours, Larry
Thanks!
Yours, Larry
A Failure!
After 18 months with a demo unit hooked up to a"Heating Box" on an experimental basis I have indeed encountered a failure with the heat exchanger on the Takagi T-KD20 I will be returning it for it's autopsy. I see a great deal of corrosion on the top of the copper finned XH and suspect that is the problem.
This was a test unit with only my labor and materials as my cost. I will probaly go to the Navien high efficiency unit as my next test model.
Stay tuned!
Rich K.
Trial and Error
Larry,
This unit was exposed to some very tough conditions. Weather extremes outside from -10 to 100 (this creates differnt levels of condensate as the stainless vent really conducts cold to the top of the unit). The "Heating Box" add-on while hooked to a well insulated in floor zone does cause more cycling of the unit.
The other test system has a Rinnai Continum Tankless with a plastic outer sleeve and stainless interior exhaust
pipe. This seems to be working fine and the in-floor is a fairly large garage for a landscaper who stores his snowplows etc in there. Thus far he has had zero problems (knock on wood)
I know you are very well versed on hot water systems and I posted this for that reason. I was a little disappointed yet not entirely surprised as I also have very hard water that I bring down with a softener yet that is still not the most desirable for a tankless.
I tend to push things instaed of babying them. I want customers to have durable and reliable equipment.
Thanks Larry, you and your wife are assets to the industry.
Rich K.0 -
Open system?
Is this a system that uses domestic waterheaters as a heatsource? And does it also supply the domestic hot water on the same system?(Interconnection)0 -
Closed System
Der Heat... they offer the open system but I would not do that so I used their closed system. It is a packaged unit "the Heating Box" by Navien America. I have used both the Takagi and a Rinnai for heatsources on the two test systems I set up.I am kind of glad I was the one who had the failure not my friends son. Although he knows the situation and wanted to try this new heat source concept.0
