reverse spin
JBW_2
Member Posts: 67
Hello all,
Is it possible that when a run cap on a single phase condenser fan motor goes bad, your motor would spin in the reverse direction?
Josh W
Josh W
Motor spinning backwards
Yes.
Larry C0 -
i suppose it could be possible to have a short in a reversible motor that might make the motor run "backwards" but i have never run across that. a bad capacitor won't make the motor run backwards, it will only make the motor spin unbelievable slow or not at all. either way its probably spinning backwards because the condensing fan motor right next to it is still running full bore and pulling air though the shroud making the fan spin backwards:)0 -
Hey Larry,
Is this a common occurrence?
Regards,
Josh W0 -
Edit to Yes.
I agree with Bill. The motor can turn in either direction at a reduced speed. The motor will be hot from a lack of airflow and higher current draw.
Larry C0 -
I've seen a Unico blower motor capacitor fail. I couldn't tell if it was running slower, it did run backwards.
David0 -
Or
It will try to start, fan blade wil try to move both ways, acts like its locked up but isn't0 -
Common?
I don't know, however it happens on occasion.
Larry0
- 123 Chimneys & Flues
