If our community has helped you, please consider making a contribution to support this website.  Thanks!
reverse spin
                    JBW_2
                    Member Posts: 67
                    Hello all,
Is it possible that when a run cap on a single phase condenser fan motor goes bad, your motor would spin in the reverse direction?
Josh W
Josh W
            Motor spinning backwards
 Yes.
 Larry C0
 i suppose it could be possible to have a short in a reversible motor that might make the motor run "backwards" but i have never run across that. a bad capacitor won't make the motor run backwards, it will only make the motor spin unbelievable slow or not at all. either way its probably spinning backwards because the condensing fan motor right next to it is still running full bore and pulling air though the shroud making the fan spin backwards:)0
 Hey Larry,
 Is this a common occurrence?
 Regards,
 Josh W0
            Edit to Yes.
 I agree with Bill. The motor can turn in either direction at a reduced speed. The motor will be hot from a lack of airflow and higher current draw.
 Larry C0
 I've seen a Unico blower motor capacitor fail. I couldn't tell if it was running slower, it did run backwards.
 David0
            Or
 It will try to start, fan blade wil try to move both ways, acts like its locked up but isn't0
            Common?
 I don't know, however it happens on occasion.
 Larry0
- 87.2K THE MAIN WALL
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
