Standpipe riser painting
MikeyB
Member Posts: 696
According to a color chart I have from Wexler Services in NYC, the color to use is Standpipe & Sprinkler "Cardinal Red"
Has anyone ever heard of a requirement in NYC that standpipe pipe risers be painted a certain color, and if so where is it and what color?0 -
Stand pipe
That would be RED and it is in the paint store. Outside just the caps have to be red unless it is a combo with sprinklers off it then the caps are to be yellow. You can pick up the brush at the paint store also.0 -
standpipes
UNLESS HE is not refering to " fire " standpipes. there are also heating standpipes.0 -
This refers to fire standpipe piping exposed inside a building hallway.0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
