How long do steam pipes last?
bob young
Member Posts: 2,177
STEAM piping usually lasts for ever. or at least a hundred years. unless it is covered with soil or concrete. then anything after seven years is a gift. threads can rot on occasion & wet returns usually are good for at least 25 years
Greetings everyone! I am involved in a heating inspection for a large monastery in Ontario. This building was built in 1891. Leaks pop up every now and then and the customer is asking that age old question: "Do you think the piping needs to be replaced?" In reading Dan's books, and in view of the faact that steam piping always rusts, what do you folks think? Is it time to trash the piping?0 -
117 Years Old
The system is pushing 117 years. Some of the condensate returns have rotted out inside walls. It's a two-pipe system with air vents in the rads.??? This leads me to think that it may have been a one pipe system and was converted at one time. How does one know for sure? I thought it was only one pipe systems in the 1890's with two pipe showing up in the 1900's. In any case, do you really think that the dry pipes could be expected to last much beyond 117 years? We're thinking of renovating and don't know if it's time to gut the inside and do all the steam piping at the same time.0 -
Steam Pipe Longevity
Do you have water hammer? That will punch holes in the steam pipes. Could you please post pictures of your system?
That's probably
a 2-pipe air-vent system. The steam pipes should be fine, but the wet returns should be replaced. That's where you've had leaks, right?
Also, what pressure are you running? The lower the better. Are there properly sized air vents on the steam mains?
117 years....
is one hell of a run! Me thinks it's probably earned it's retirement.There was an error rendering this rich post.
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
