Radiators
kpc_18
Member Posts: 9
if it is a true steamer...no connections accross the top , no. The downside is possible leaks under higher pressure and junk entering the system.
Radiators
Can I use a steam radiator on a hot water system and if so is there any negatives?
Thank you for your time.0 -
It depends
if there are hydraulic connections at the tops of the sections as well as the bottom, it will work. Post a pic if you're not sure.
