Towel warmer with Steam Heat?
ALH_4
ALH_4 Member Posts: 1,790
I would treat the towel warmer as a separate from the room heat. When covered with towels, the towel warmer will not provide much heat to the room. Possibly you could leave the existing radiator and install an electric towel warmer on a timer.
