no heat = no DHW
Timco
Member Posts: 3,040
I have a service call tomorrow for a WM GV-4 that will not fire. It's a few towns north and I will be bringing a HSI. Question is, since these folks have an indirect, short of getting the boiler firing, is there no way to get them hot water? Has anyone seen a standard 40 gal WH on the DHW system as a back-up for hot water needs? I hate to see them without both...
Tim
Tim
Just a guy running some pipes.
An electric
HW tank could be plumbed easily, IF you have a 240V 30A circuit nearby.
Or a long extension cord to a dryer outlet
Indirect tanks with back up elements, like some solar tanks would sure be nice for back up in cases like this.
I think we will be seeing more indirect tanks built with elements or provisions for.
hrBob "hot rod" Rohr
this is why
this is one of the reasons i like to use a 40 gal. elec. water heater plumbed into a tankless in the summer it only uses a mim. amount of oil in the winter the tank serves as a BIG themos and if the boiler does not fire they have elec. back up my thought royboy0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 27 Recall Announcements
