OT
Hvacman
Member Posts: 159
Thermistor on a weight, waterproof wiring connections, roll of wire, correct resistance value for length of wire run as needed.
OT
What is the most practical way to measure water temperature at the bottom of a 425 ft well?0 -
Accurate or Simple?
Just run the pump for a few minutes and measure at the nearest cold water faucet running. Or if you check with a local well driller they can give you an average. Best Regards.0 -
Thanks for the reply, no pump in well will contact well driller for average temperatrues.0
- 167 Indoor-Air Quality
