OT
Hvacman
Hvacman Member Posts: 159
Thermistor on a weight, waterproof wiring connections, roll of wire, correct resistance value for length of wire run as needed.
  • Phil_17
    Phil_17 Member Posts: 179
    OT
    What is the most practical way to measure water temperature at the bottom of a 425 ft well?
  • Blackoakbob
    Blackoakbob Member Posts: 252
    Accurate or Simple?
    Just run the pump for a few minutes and measure at the nearest cold water faucet running. Or if you check with a local well driller they can give you an average. Best Regards.
  • Phil_17
    Thanks for the reply, no pump in well will contact well driller for average temperatrues.
