Update on Stove Gas Shutoff Location
D107
Member Posts: 1,944
A month later and I've gotten different stories from local techs. First note that my town uses the NY Uniform Building and Fire Prevention Code. A plumber who does alot of work in my area and all over Westchester says that a shutoff behind the stove rear indent--raised a bit on black pipe coming through the floor after which the flex connects to the stove is good, that a shutoff accessible in the basement would not be acceptable.
Another plumber says on all his new construction jobs, Con Ed mandates the side cabinet shutoff location. Who has authority here; what happens when code and utility disagree?
Thanks,
David
Thanks,
David
The utility can
add to the code but not take away. In this the utility has authority.0 -
thanks Tim; hard to verify policy on utility website
Problem is, some solutions create more problems. Also new construction policy may differ from that for old housing. I think unless the job is done very carefully in the manner you suggested in the prior thread--probably more carefully than most plumbers would care to plan for--that side cabinet method might very well prove quite inferior to the old rear-of-the stove method.
Thanks,
David0
- 62 Biomass
