staged a/c would it work?
Empire_2
Member Posts: 2,340
Anything is possible, but keep this in mind. The city Multi is one unit feeding multiple Evap's. If you use multiple condensers you can and will have an oil issue. Once the oil leaves the condenser, it does not know or is not guaranteed to go back to that condenser. Perhaps a small chiller may better serve you.
Mike T.
Mike T.
assume a building with 24 1000 sq ft. spaces each with a separate furnace and a/c condenser [on the roof].
if you had the right control system and the right form of freon interconnection ; couldn't you use only one of the condensers to supply cooling on very mildly hot days to all the spaces.then as the heat load increased more of the condensers would be brought on line.
seems to me that this could be more economical or am i wrong?
at the very least it would reduce the total runtime and wear of all the condensers-nbc0 -
Nicholas, look at the Mitsubishi city multi
Yours would be a perfect application for it. Super efficient and quiet. Tim0 -
it depends
It depends.Who going to pay the gas/power bills..tenant or landlord?
24000 sq feet makes for a very big ac/heat plant.
Also most 1000 sq ft space is setup so the tentant will have to pay for maintence and repairs on the equipment.I know with some building in my area that the landlord makes the tentant pay for replacement equipment if needed.
yup, chilled water...
.0
- 123 Chimneys & Flues
