Wood Steam Boiler
Ya.... there was a company down in west virgina, i believe, was making them. Dont recall the name but I had some lititure. I'll dig aroung in the barn, see if I can find it... might take a day or two....
  • Rob_52
    Rob_52 Member Posts: 4
    Wood Steam Boiler
    I have a customer who wants to replace their old Wood/oil steam boiler. Does anyone still make one? Or even a wood only steam boiler. 85,000BTU
  • Rob_52
    that is dual fuel but its not steam. Hopefully wrench puller will find something. These people are very determined to retain their original heating system.
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,578
    wood boiler
    what about finding an old coal boiler and changing the grates for wood and using that. you can sometimes find them on ebay for small change.
    maybe with a false waterline you could have both boilers working as a tag-team together?nbc
  • Eric Johnson
    Eric Johnson Member Posts: 174
    Custom Fab
    There's a guy in Dundee, NY named Gary Switzer who makes custom pressurized wood gasification (chip and chunk wood) boilers. I'm not sure if he also makes steamers, but I wouldn't be surprised. Sorry, I don't have a number, but he can probably be reached through directory assistance.
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,422
    Is dual fuel allowed in your state?
    They are not allowed in Mass. Not even allowed in the same flue. I would check that before special ordering a unit. Do they realize how much wood a steam unit is going to burn through? There was a reason it was a full time job back in the day for firemen, the ones making fires not stopping them.
    cell # 413-841-6726
  • Rob_52
    in VT Dual fuel is allowed only if it is a dual fuel boiler not separate appliances. I think he is going to be stuck with an oil only or change out the steam system but he really likes his wood steam boiler that he has now but its developed quite a few small leaks and 1 big one over the 35 years it was installed.
