who makes short water heater
bob eck
Member Posts: 930
can you use a tankless gas water heater?? check out noritz
short water heater
Afew years ago I saw a natural gas hot water heater in a crawl space that was about 3 ft tall. Now I need one on a job and do not know who makes them. Anyone know of a name brand?Idle hands are the devils workshop
GSW used
to make a 20 gal gas fired unit about 3' tall. I did a job where I did 3 in parallel to get 60 gal. worked great0 -
Do you have a furnace or a boiler as a heat source ?
If you have a Boiler ,How about a Indirect ? Heattransfer makes a superstor that is very short.(Installed one a week ago)
If you have a older furnace and it time to change it anyway how about a Hydro air system with domestic H2o production.
Or you can install electric stubby Waterheaters.
as per you orig. question , I think some of the stubby waterheaters have been discontinued ,I think they were not very efficient!0 -
I think State
made a real short version. Bock has a new low model also. maybe just 20 gallons however.
hrBob "hot rod" Rohr
I think most manufacturers stop making short (lowboy) gas water heaters when the flame guard models became mandatory.
The lowest ones I have found where 50" for a 40 gal.0 -
short heater
The customer has an old steam system and an old boiler, also lots of underground springs in basement so boiler and water heater are prone to flooding.I think the real short heaters are a thing of the past. I might look at at a gas on demand heater . Thanks for your helpIdle hands are the devils workshop
triangle tube makes one model phase III stainless steel indirect water heater that is horizontal and you can mount it high up on the wall and run it off the boiler.
check it out at www.triangletube.com0
- 50 Industry Classes
