how does this valve and fitting work?
Brad White_185
Brad White_185 Member Posts: 265
Look in the Systems tab under Hot Water then under Gravity Hot Water.
http://www.heatinghelp.com/heating_howcome1.cfm
Look down near the bottom of that page...
IPTWOTW
  • G L Caplan
    G L Caplan Member Posts: 1
    how does this work?
    Hi folks...3 plumbers cant tell how this works
    One heat guy says theres a "venturi" that sends water into the radiator..but I dont see what makes the water circulate thru the radiator
    These pipes are the only ones entering this hot water radiator. The heat guy says the radiators on the floor are in series. The home owner says the radiators that have these valves, I believe all on 1st floor get nice n warm
    Any one know the straight dope on this??
  • JohnNY
    JohnNY Member Posts: 3,231
    Venturi might be right.
    I think of it more as a vane.
    A portion of the water flowing past the valve is directed into the radiator by the vane and so that same amount of water is drawn out of the radiator simultaneously.
    The heated, less buoyant, water finds its way to the cold portions of the radiator and that's how you get warm.
    Someone else may do a better job explaining.
    Consulting & Troubleshooting
    Heating in NYC or NJ.
    Classes
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,578
    mystery valve
    we have seen a picture of this type of valve on the wall in the last few months maybe there was some description with the picture--nbc
  • tim smith
    tim smith Member Posts: 2,763
    I think it is like a monoflow tee
    As John said, a venturi effect forcing higher velocity water into radiator from valve and then returning at a lower velocity back to valve. Neat idea. Tim
  • gerry gill
    gerry gill Member Posts: 3,078
    gwgillplumbingandheating.com
  • Mark Eatherton
    Mark Eatherton Member Posts: 5,853
    Uh huh...
    Tis a unique valve. I have the Honeywell Hot Water Gravity book in my office. i will bring it home and copy that page.
    I love the print and wording used in their books. In one place, they speak of systems operating without the Honeywell #1 heat generator and say "If you have a system that is working well without the heat generator, it's OK, we understand..." or something to that effect.
    ME
  • Jim Bennett
    Jim Bennett Member Posts: 607
    Go Brad!....
    Love the internetese, IPTWOTW
    It pays to wander off the wall.
    Jim
  • Timco
    Timco Member Posts: 3,040
    Dave Stroman has one I saw while I was at Wetstock. It has a divider in the middle, and forces water into the rad from one side and sucks from the other side. Very unique valve...
    Tim
    Just a guy running some pipes.
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,538
    From the Library
    Here's the patent for the Unique valve
    And if you look in this Honeywell catalog on page 23, you'll find more on the the valve.
    It does pay to wander off the Wall.
    Retired and loving it.
  • joe_108
    joe_108 Member Posts: 5
    What a great book to have in one's library. I have never seen this valve installed, but i did give Dan H a OS fitting a few years back
  • Neat!
    I like the next section where it describes the huge T'stat with clock as "small and attractive". LOL...
    Great publication, now part of my files, thanks!
  • Edward A. (Ed) Carey_3
    Mercury
    Really cool book Dan.
    Did you read in that book how they talk about how SAFE Mercury is????
    Ed Carey
  • Big Will
    Big Will Member Posts: 396
    Dan is the man
    with the history. Dan the best part about the way you present your books is the blending of history with modern technology. So often I find people in the trades focusing on the newest technology and products that will be disposable in a few short years. Your application of the history of the trade commands respect.
    jerryvinson123
