Using the Gill and Pajek Venting Capacity Chart
FJL
FJL Member Posts: 354
After reading about their "Balancing Steam Systems" booklet, I decided to pick it up. Do I really need to remove the air vent to figure out how fast steam will reach the open pipe (that is the same as the end of the main, right)? Is there a formula I can use instead if I know the size of the main and its length?
  • Brad White_203
    Brad White_203 Member Posts: 506
    The Noel Method
    Using the Noel Method (as they aptly call it) will save you time. I did it once and it corroborated my size by size calculations and best guessing in a way that humbled me. It is reality.
    If you want to do what I did, take off the feet of pipe, the inner volume and some assumed pressure, be my guest! I have a spreadsheet I developed to ease those calculations. Write me off line and I can send it to you.
    Brad
  • FJL
    Thanks
    Is your email addy available somewhere?
  • JAMES MEDINA
    JAMES MEDINA Member Posts: 16
    NOEL METHOD
    Send it here too! FIREBIRD662000@YAHOO.COM
    THANKS IN ADVANCE
  • Brad White_202
    Brad White_202 Member Posts: 105
    just hit \"reply\"
    and there is my addy encoded for bot protection. bewhite "at" rcn.com
    I will have to retrieve that spreadsheet from my "other home computer" this weekend and I will send it along.
  • FJL
    I hit reply . . .
    but only see my email addy embedded. Not yours. Anyway, I'll drop you an email from my home email. I'll reprint my gmail addy here encoded as well: fjloss "at" gmail.com
    Thanks and Happy Thanksgiving.
