STEAM PRO IN CHICAGO??????
heattech
Member Posts: 2
I Replaced a steam boiler in a very old two flat in chg,il the problem is that there is to much water in boiler after a few cycle. I can see that i have very slow water return to boiler during heating cycle but more water coming back when the call for heat ends, thus causing the boiler to over fill. what can be done to take care of this problem, later i find out that this was happening with the old system as well could i have a piping problem in the walls some where, leaking some of my return water during the heat cycle, need some help thank you.
Any steam pro in Chicago??? Uneven heat
Is there anyone in Chicago that knows how to tinker with Steam heat???? I got an 8 unit building and 2 of the apartments are cold or take longer to heat.!!!!
Its driving me crazy!0 -
Find a professional
at the top of this page under the resorces button.0 -
I will probably be in Chicago on a couple of projects....
I'm in Find a Professional
BoilerproThere was an error rendering this rich post.
IN CHICAGO when??
BOILER PRO EMAIL ME AT FIREBIRD662000@YAHOO.COM0 -
We are north west side based - 70 yrs in biz. E-mail me atjlillis@alltemp.com
John0 -
We handle the South Side of the city and would be happy to help in anyway we can.
Ralph's Heating Service,Inc. 773-375-46000 -
Start with the basics. Is the boiler surging and the near boiler piping correct.0 -
Also if it is a slow returm back to the boiler check to make sure all the radiator valves are fully open. They can not be in a partly open position it will cause water to trap in the radiator untill a off cycle and then possable flood the boiler.0
- 167 Indoor-Air Quality
