increase capacity of tankless water heater
mike t_3
mike t_3 Member Posts: 6
need to incerase the capicity of an electric tankless water heater, without increasing the existing 50 amp line to the siebel heater. thinking about a small storage tank,a circulator, an aquastat, and a tempering valve. any ideas?
  • Brad White_185
    Brad White_185 Member Posts: 265
    How about
    a small storage tank, a circulator, an aquastat, and a tempering valve? :)
    An HTP Super-Stor Coil booster is a great way to store hot water and buy you time. If you get a regular Super-Stor with a hydronic heat exchanger that can set you up for future sources such as solar or a water or ground source heat pump.
  • kpc_17
    kpc_17 Member Posts: 3
    GFX heat...
    exchanger...kpc
  • singh
    singh Member Posts: 866
    pre heat
    with solar storage in front of tankless. If no solar yet. At the very least you would have warmer, perhaps room temps stored in tank before unit, making the temperature rise smaller for the tankless, resulting in increased GPMs
