increase capacity of tankless water heater
mike t_3
Member Posts: 6
need to incerase the capicity of an electric tankless water heater, without increasing the existing 50 amp line to the siebel heater. thinking about a small storage tank,a circulator, an aquastat, and a tempering valve. any ideas?
How about
a small storage tank, a circulator, an aquastat, and a tempering valve?
An HTP Super-Stor Coil booster is a great way to store hot water and buy you time. If you get a regular Super-Stor with a hydronic heat exchanger that can set you up for future sources such as solar or a water or ground source heat pump.0 -
GFX heat...
exchanger...kpc0 -
pre heat
with solar storage in front of tankless. If no solar yet. At the very least you would have warmer, perhaps room temps stored in tank before unit, making the temperature rise smaller for the tankless, resulting in increased GPMs
- 120 Geothermal
- 394 Solar
