boiler push nipples
EBEBRATT-Ed
Member Posts: 20,295
I have done it both ways. You can leave the old ones if they look ok or put new ones in. Havent had much problem either way.
Ed
Ed
boiler push nipples
I have a Utica Starfire III boiler that was a leaker after one year. I replaced with a new block under warranty. I disassembled the old block to get it out of the basement. When I did I found the problem to be a broken push nipple in the lower waterway. It was a 7 section boiler. I would like to salvage the boiler and make it a 4 section. I have never assembled a push nipple boiler before. My question is can the push nipples be used over or should I remove all of them completely and get all new ones.0 -
Push-Nipples
Vernon, WOW a "push nipple problem". I would say get new-ones. Push-nipples usually are a one-shot deal because the holes they fit-into are not exactly perfect. Its almost like trying to re-use a gasket. You may get lucky, maybe not.0 -
I could have been lucky...
But I've never had a problem reusing push nipples.0 -
Push Nipples
Great Al!, Unfortunately in my case, I wasn`t.0
- 120 Geothermal
- 169 Indoor-Air Quality
- 396 Solar
